Ford Focus fault
14 years 1 month before - 14 years 1 month before #26090 by manual-mecanica
Manual-Mecanica Answer on the Re: Ford Focus Fair
Nuevoenna wrote:B) Hello; In my opinion, the battery must be badly contact. Check and clean with bicarbonate the contacts of it and that's it. Luck: Dry:
Mmmm ... now I remember ... a co -worker also told me that it could be that, to sand them (it convinces me more to put water and bicarbonate). That could also be a possible problem (between the entire battery, the alternator, the starter engine .......).
I didn't remember it. Tomorrow then I try it to see. And ... nothing happens because it takes them away, right? (As long as I do not touch the two or leave them out there, so I suppose something would happen, but I say that ... nothing, tomorrow I try it when I return from work and say something.
Thank you! And tomorrow I keep looking at what you say and put if I fix it when cleaning the contacts.
-Eduid: what ... what nonsense that the air and the lights are turned on ... : UNSURE:
Latest edition: 14 years 1 month before by .
14 years 1 month before #26092 by manual-mecanica
pdr the noises of relays and other things you have, without turning the engine stop the battery.
