VITZ 1SZ Motor Heating
14 years 2 months before #25424 by manual-mecanica
Manual-Mecanica response on the Re: Vitz 1SZ Motor Heating
Hello friend, all 4T engines work with the same principle and an overheating in their march if everything works correctly may not be well, I suggest that you take a strobe lamp and control the advance of the ignition, if it is behind heating, try that, greetings.
14 years 2 months before #25560 by manual-mecanica
Hello everyone.
I tell you: my car is without thermostat. Another mechanic told me that the radiator was cold and the engine was hot, that is, it did not circulate water and that is why it was heated, I made the radiator clean again and then the temperature was more even, that is, there was not much difference between the engine and radiator. Purge the system.
Keep warming up !!!!!!! So much so that it starts to boil!
I turn off the car, I hope I cool, water increase, etc. And when I want to turn on, it is a lot, it is as if the vehicle was carburetor and there was no gasoline and it takes a long time to turn on and then loses the car.
That is since last Friday. Today try 9 times to turn on hard on. Only from today I was throwing water through the escape! The truth is that I don't know what to do !!!!!!
14 years 2 months before #25561 by manual-mecanica
Comrade Maurysio has a water leak anywhere a mangue, radiator, water pump, mangraqs of cagrade cage caradeqs water drinking thermostat or stamps of the engine cover of the radiator health
14 years 2 months before #25562 by manual-mecanica
: Laugh: Maurysio in what you at the rolled enj the car and when you stop looking at underneath if you leave any water drip I comrades
14 years 2 months before #25564 by manual-mecanica
Hello, you do not try the tuning, obvious that when it is hot and behind you will not tear you well, and if you throw water through the exhaust pipe you may be condensing or the lid joint has been broken by the high temperature, I clarify that the water does not cool the engine, but that absorbs the temperature that it lifts, never adds cold water with the hot engine with the hot engine because you are going to break it.
