Probemas with a corsa evolution of 2007
14 years 2 months before #24555 by manual-mecanica
Manual-Mecanica response on the re: probemas with a corsa evolution of 2007
I already check the gasoline filter and just in case the spark plugs are changing all and the cables are well and I don't know where to go, since this fret in the slopes does not upload even for the hell you understand me
14 years 2 months before #24559 by manual-mecanica
Hello; If in the slope that you say notes that the engine is revolutionized and the car does not advance it is a sign that the clutch is skating. Another test is to put the handbrake and in 5th march accelerate and take out the car; If you stop is good, but if it accelerates and does not advance it is that it is skating (smell of balata). See you.
14 years 2 months before #24564 by manual-mecanica
Check out the tuning and make sure that Damper's Sentral bolt is well tight, usually play because of the key.
14 years 2 months before #24566 by manual-mecanica
You have to check that this position to point the engine can be a time stranger of site, check the piñon of the Sigual always generate a game in the key due to lack of tightening, another check the pressure and the gas pressure regulator since excess or little pressure can generate lost power in slopes .............
14 years 2 months before #24568 by manual-mecanica
Well hello, control the air filter that is not very dirty, if possible change it, it can also be the MAP sensor since its work is to measure the admoferic pressure and uphill changes the pressure and the sensor can fail.
