Probemas with a corsa evolution of 2007
14 years 2 months before #24525 by manual-mecanica
Probemas with a corsa evolution of 2007 published by Manual-Mecanica
I have problems with the engine of a corsa evolution of 2007 since the engine loses strength in the slopes pence that was the problem of the injectors and sends them to clean and continues with the problem I do not know what the most can be
14 years 2 months before #24527 by manual-mecanica
Manual-Mecanica response on the re: probemas with a corsa evolution of 2007
I recommend you to go for the basic, check the gas filter that is not covered, checker
14 years 2 months before #24529 by manual-mecanica
If you discard the coil, spark plug wires and these. Check the clutch that may be skating since it is in the slopes where your problem occurs.
14 years 2 months before #24541 by manual-mecanica
Thanks I'm going to see that tomorrow and I tell you how I went with that
14 years 2 months before #24554 by manual-mecanica
Hello good afternoon as I check the Embregue since I am taught the automatic and not to this manual type and I have no idea where the EMBREGUE of this car is understand me
