Hyundai Matrix
13 years 9 months before #30231 by manual-mecanica
Manual-Mecanica Answer on the Re: Hyundai Matrix
Hello
my name is Enrique, I have the same problem as you in the Hiunday Matrix 1.5Cdri, I wanted to know if you have managed to solve the problem, and if you can guide me, in my case, I have changed injectors, diesel filter, heaters, starter engine, diesel injection pump, drums, with the huge expense that this involves changing pieces and the problem remains the same, in the morning after the morning after the morning. It starts, it does the runrurnrurnrun, and so you can be minutes that it does not start, if you push it in less than 3 meters, then during the day there is no problem, it starts more or less well.
At this step you would have to change the entire engine
thanks for your help
Enrique
13 years 9 months before #30267 by manual-mecanica
Hello colleagues because of the little that it seems that it can be an air intake and in the morning it is difficult to start because if it were electric he would give a fault notice in the already kike01 painting, the vehicle is almost further carbiar. Put a piece of hose transparent to the entrance of the diesel to the pump and the next day check if the hose passes air through the hose or if everything passes and so you can make the diagnosis.
