Help with Astra 2002 heating
14 years 1 month before #22906 by manual-mecanica
Help with Astra 2002 heating published by Manual-Mecanica
Hello, how about everyone in the forum I need help with my astra 1.8 Model 2002 What happens is a little bought but has a fans failure is heating and I do not know why they are not activated and the thermostat already removed the thermostat already purge the radiator I only need to know if the temperature bulb is good I do not know how to check it and how many it brings only that one is located in the machine part of the machine. The weirdest thing that the fans were working and actibavan at a temperature of 80 degrees that is more or less half but as the blades of the air conditioning were dancing the changes after that the fans did not work anymore I do not know what to do help me please. : Dry:
14 years 1 month before #22918 by manual-mecanica
Manual-Mecanica Response on the Rera 2002 Help Help: Help
First of all, it verifies that there has been no loose cable, both at the top, as well as in the lower one. Check if you do not release the temperature bulb cable. In the worst case, you would have to place a relay and make it independent to the electrventilator.
14 years 1 month before #22921 by manual-mecanica
If the bulb was connected all the harnes looked well and replace the thermostat, clean the radiator and do not know what to do more. On the other hand I do not know where I have the fuse box already looking under the steering wheel, in the glove compartment and I do not see it anywhere if I could tell me too I would appreciate it
14 years 1 month before #22932 by manual-mecanica
First of all, checca in the lower part of the torpedo a black lid will take it out and to be the fuses if they are not there then look in the engine if they are, if you do not find them or want to provise if they walk, you have two things you have first walk the electros direct from battery with two cables, if they are disconnecting the bulb and with a cacble dwings the two pins to close the servant if they start the problem. Let's gia. It is nothing from the other world you can repair it Tankilo
14 years 1 month before #22936 by manual-mecanica
Give us more information about your case and we will help you
