Nissan chassisbina motor rings 2001
14 years 4 months before #22858 by manual-mecanica
:( I request an advice, engine with 19 thousandth wear, medicine that cut in 030 "
thousandth Motor with excess smoke
14 years 4 months before #22868 by manual-mecanica
Hello, if you have no money to solve that problem of recommending to buy some rings on measure and file them until leaving the opening measure that is 0.15 to 0.20 but it is a momentary arrangement it is best to rectify cylinder, change piston and rings .....
14 years 4 months before #22879 by manual-mecanica
I have a doubt the rings would be in .020 "with the same pistons that I brought? Thank you for your help
14 years 4 months before #22880 by manual-mecanica
The pistons to what extent are, I suppose that in standard ???? I do not think you should put them in 20 if you use the same pistons, the most logical would be standard - standard rings; Pistons in .020 " - Rings in .020", but let my teacher ask and pass you the fact to see what he tells me.
14 years 4 months before #22920 by manual-mecanica
Thanks Pineda, that's how it is in STD. And he told me the rectifier that has .019 "of wear, to see if you can give you the light of rings, or how I can do or invest so much thanks
