motor temperature
14 years 3 months before #24365 by manual-mecanica
Manual-Mecanica response on the Re: motor temperature
Ola friend, I have the keyboard with nas less letters like that, if I have not done well, I tell you, I also have this problem, and I gave myself to my country the model is delayed between no and two years, and this takes you to you to make a mistake, you ask the cylinder head packaging, this pede comes with senses less of access to refrigerant, because the seller believes in the paper and not in the paper 96 ACA appears as year 98), beno we go to other data verifies that the scam of Scion the one that is due to the riador is not soft, the engine is hot, it tends to bend and restrict the refrigerant,
14 years 3 months before #24399 by manual-mecanica
Hello friend, well look at this temperature, I will tell you that there are many causes for which an engine can heat, but because of what you say there are no doubt, if the hoses swell and throw the water by the deposit you have the joint of the burned lid, but you can have the fissurated tepa and that is more serious
14 years 3 months before #24400 by manual-mecanica
Hello, eye looks that some engines if the thermostat is removed they heat more, since the water instead of circular through the radiator only does it inside the engine
14 years 2 months before #24420 by manual-mecanica
Hello friends, ask, what do you mean by the Board, it is the lid, here in Chile our technical volume is differently in some points, thanks friend that you are well.
14 years 2 months before #24443 by manual-mecanica
Hello, well, the Board becomes the packaging, that is, what is going between the cylinder and the Blok cover, greetings the name in English I do not remember
