Temperature sensor
14 years 6 months before #20890 by manual-mecanica
Manual-Mecanica Response on the Re: Temperature sensor
You are very right when putting the sensor took a cable I already put it well but the car trembles a lot when I turn it on and the revolutions are raised and lowered and the engine is listened a bit but already marks the temperature well ... what do you mean with the bleeding of the vehicle? I made the change of engine oil and transmission 5 days ago although the problem already has a month.
14 years 6 months before #20904 by manual-mecanica
Has but the irregular relief is before making the temperature sensor change? If so, can you check the state of the Relay regulator, in addition to any false air input or loose hose and the state of the air filter to start.
14 years 6 months before #20992 by manual-mecanica
Compadre This is going out of control, yesterday almost choco the car was accelerated alone and I could not stop luck Revice the air filter and it is fine, revise the hoses and everything is in its place well tight what do you recommend me? thank you
14 years 6 months before #21015 by manual-mecanica
It is difficult for someone without mechanical knowledge, but it replies somewhat vehicle has an electronic accelerator or by piola?, so you describe this demacious accelerated or very little.
14 years 6 months before #21023 by manual-mecanica
Ok thanks again for your time, look my car has an electronic accelerator, look he came driving when sudden High revolution does not be restless or accelerates anymore, it stays accelerated on so and so it is already a company of the explorations that I mention you .. I do not know if I can put the video of the car to qui in the forum so you can see how it turns and how it is heard, well thank you
