ELVED CONSUMPTION
14 years 8 months before #19318 by manual-mecanica
Manual-Mecanica Response on the Re: ELVADO CONSUMPTION
The engine temperature marks me on the panel well. I do not make a change or have touched it since they told me that the engine would have changed it. Although it seems to be that it is fine. If I clean the air filter nothing more.
The car lacks enough power does not exceed 200 km and it is hard to get there, it has 192 hp.
14 years 8 months before #19321 by manual-mecanica
Well ... some of the causes of consuming a lot of gasoline is:
1st because the filters are obstructed.
2º The temperature sensor of the refrigerant liquid or LAMDBA probe Send erroneous signal to the switchboard.
3º That you have leaks somewhere.
4º A foul on tuning and for the kilometers you have would not be surprised.
5th Lack of air in the mixture or excess gasoline in the mixture.
Another thing is to change workshop because some are very mammals. (I will know them there are some mechanics)
Well you will tell, a health
14 years 8 months before #19323 by manual-mecanica
Thank you, I will start doing these things and I will tell you if you get well ..
Thank you friend
14 years 8 months before #19324 by manual-mecanica
Well, many of all Friend.
I await some news and if it is a good better, hehe.
A health
14 years 8 months before #19328 by manual-mecanica
Hello my esteemed, they have not put the scaner to see if it gives any hidden code? Why do I think if you have a damaged sensor, should you give a code?
