ELVED CONSUMPTION
14 years 8 months before #19331 by manual-mecanica
Manual-Mecanica Response on the Re: ELVADO CONSUMPTION
In theory you must give some JGAB error but if you give it, only the mechanic knows.
14 years 8 months before #19332 by manual-mecanica
Hello, what is the scanner but if I know that they have put it in the BMW diagnosis machine and it does not give any faults.
Tomorrow I pick up the car and tell me if they have seen something today, with what they tell me I put it here.
14 years 8 months before #19334 by manual-mecanica
The scanner is the diagnostic team or at least it is what I understand.
Having tell you Borja Bueu.
A health
14 years 8 months before #19336 by manual-mecanica
It is correct, the scanner is another computer that normally uses mechanics to verify if there are codes, which represent a failure or several. There are generic and factory codes. Normally the scanner also indicates to which failure the code corresponds. From 1998 ^ a connector called Obdii is used, the Scaner cable is connected there. SLDS
14 years 8 months before #19345 by manual-mecanica
Hello, they have called me from the BMW and they have told me that the sensors are not right, they will look again at the car's compression.
I have called the Coiche who sold me and he told me that his mechanic did an oil cover, and before that the car was perfect.
Can you have something to see this?
greetings
