ELVED CONSUMPTION
14 years 8 months before #19286 by manual-mecanica
ELVED CONSUMPTION PUBLISHED BY MANUAL-MECANICA
Hi there! I have taken it to several workshops, the Somda Landa has changed, the catalyst was stuck by consumption, we changed it TB following the car with the same symptoms.> Later we cabied the injectors, they checked in the BMW the caudalimetro and put the switchboard in parameters.> The caudalimetro is perfect. The compression of the engine tb is all the cylinders in 10.5 They are fine.
These and desperate since the mechanics do not want to wet with my car because they will change me a lot without knowing if it will be fixed ...
please what can it be ??? The car when the computer is standing on average indicator putting it to zero, when the car is standing, the consumption is triggered only the consumption of the screen is progressively raised in the accelerated screen is continuously going down this continuously ..
can you help me please ???
14 years 8 months before #19301 by manual-mecanica
Manual-Mecanica Response on the Re: ELVADO CONSUMPTION
It sounds like a switchboard or that some of its sensors are sending a wrong signal and gasoline goal by a tube.
The engine temperature is fine ??
Have you done something else to the car apart from what you have named?
A health
14 years 8 months before #19314 by manual-mecanica
Well, I have not told me in the BMW of Burgos who have put the switchboard in parameters. APARTE We change the Ijectors obtaining the same result.
The engine temperature I think they have not measured it, I will comment on it. The sensors are many who could be failing to buy them ???
Another house that makes me is when I am going to change marches in d is revolutionized a lot as if it is in S. it does not always do it but something tb fails in the gearbox ..
should the spark plugs change the oil and the filters I know that so it would be a little more consumption, cslculating that they are in poor condition about how much could the consumption lower me?
Thanks for your help
14 years 8 months before #19315 by manual-mecanica
Regarding whether something more apart from what was named, until the day I have had it, which is 5 months ago (they sold it to me like this) and the owner apart from deceiving me with the Kmde 240 thousand to 140
14 years 8 months before #19316 by manual-mecanica
Basic engine sensors I think they are 8 or 10. Do you have temperature indicator? If so, how much does it mark ??
Have you looked at the filters (gasoline, air, oil) have if they are obstructed? Have you made any oil change with your filters after the high consumption?
The car is fine ?? or do you notice that the engine you have is missing?
All information that proportions is very useful.
A health
