Hello, with respect to the theme of the monoblok it is a very delicate matter since if you make you seal the cold monoblok, it may be the case that the seal obstructs some cooling or grease duct the definitive breakage of the engine, on the other hand there is the matter of knowing where exactly the fissure is, this is complicated to determine, if the mechanic gave the fissure to the fissure in the exact point. This option is compared to others is the most economical.
A slightly more effective option is to make a cold welding of the fissure, it is a more complex process than the seal but in the long term more effective and reliable the problem as in the previous case is to find the fissure, anyway if you decide to perform the sealing or the welding you should know that your engine will no longer be the same as before the mishap may endure less in its useful as expected than expected. The most effective solution unemployed at the same time is the most expensive is the replacement of the engine. I greet and tell me how it has gone.
