Please help me with Mustang 5.0l
14 years 11 months before #17149 by manual-mecanica
Manual-Mecanica Answer on the Re: please help me with Mustang 5.0L
Try to do the release a little, in the automatic Mazda Moelos, it passes the same, and it was for dirt in the admission body, it is cleaned complete and ready, when it does not work, it leaves a little more accelerated l Relay, since when you put the gears the engine load is greater and the revolutions low
14 years 11 months before #17179 by manual-mecanica
Thanks, already remove all the multiple of admission including the acceleration body by giving it a complete washing and also tries to raise the gait revolutions in emptiness and what it does is give a sudden jalon at the time that the box applies and turns off, investigating a little in a manual of Ford (Watzon) I read that this type of transmission is electronically controlled and the problem may not be unleashed of torsion and keeps the box coupled with the engine in a relationship of 1: 1 so the engine does not have the nesessary torque to hold (I imagine it is as if with a Standard box you would like to advance initially in third), so now check the transmission signals and the transmission control solenoids, wish me luck, and it is never for more than any comment. greetings.
14 years 11 months before #17180 by manual-mecanica
Greetings friend, well this is an answer and supposition since I do not have much experience in the mechanic I love but I am still studying it, in short a day a classmate in the school in automatic transmission The transmission is because it is the engine problem, so I suggest the same but in an inverse way, your engine is in perfect condition so you comment then what I tell you is that you check the trnasion the most pressed as you can and so you will realize that it is the problem of truth.
14 years 11 months before #17206 by manual-mecanica
Thank you for the comment, because as the turbine towards a kind of whistle already lowers the box to change the turbine and take advantage to regularly review all the components, in great mess I went to put myself to put myself but I am not in this way and if I have something it is to be stubborn until you find the solution and disappoint the fault, I will be commenting as I was and I still thank your comments.
14 years 11 months before #17220 by manual-mecanica
Well, uploading an option but consumes more and it is heard too acler. The problem is admission, the solution was released by the brake pedal and improvement checks the engine magueras towards the brake book B)
