Purgated Clutch Ford Ranger Hydraulic System
15 years 2 months before #15411 by manual-mecanica
Purgated Clutch Ford Ranger Hydraulic System published by Manual-Mecanica
To all, I just had just changed the slave cylinder of the troca and just purge me and I thought it was the same as the brakes but when I act on the pedal and I open the pothoguer does not feel tight is not working I have read something that I have to lift the truck so that the master cylinder is horizontal, some others tell me that the purge procedure is different, someone knows it.
15 years 2 months before #15414 by manual-mecanica
Manual-Mecanica Response On the topic Re: Purgated Clutch Ford Ranger Hydraulic System
Simple fill the liquid deposit open the bleeding from below and let it drain when it comes out enough closure and action the pedal :)
15 years 2 months before #15470 by manual-mecanica
If you don't lift her from the front, you're wasting your time ...
15 years 2 months before #15496 by manual-mecanica
I will share the method that worked me according to me it is not possible Bottle with brake fluid so that the hose is submerged in the fluid (without the possibility of grabbing air) the liquid deposit watches that it is always full, you open the pothar That the hose is completely filled with liquid, this did not achieve this so what I did was close the potharm, act the pedal, to leave it in the background to open the pothogue only until I saw that the air bubbles came out and immediately close the pedal the pedal became hard and continue and that was faster, I hope you serve this experience greetings and thanks for the answers.
15 years 2 months before #15508 by manual-mecanica
I usually exact the same way as the brakes and there is no problem, provided that the bomb is good clear, what happens is that it feels ditinto because the pedal recovers a little more slow, but they already told you vast options tested options and posts which one that did work for you thus help other users, as I tell you in Hyundai, Toyota ages it as the brakes and there is no drama.
