Pesquise no MDM
Boletim
Hastes de alternador
  • Autor do assunto
  • Pensionista fresco
Avançar
14 anos 3 meses antes #24402 por Manual-Mecanica
Hastes alternador publicado pela Manual-Mecanica
Como posso mudar os rolamentos de um Toyota Tercel de 1996
  • Autor do assunto
Avançar
14 anos 2 meses antes #24464 por Manual-Mecanica
Resposta Manual-Mecanica no Re: Mastes Alternador
It is a bit difficult, you must release the central nut of the pulley, to achieve it you will have to put the alternator on a bank screw and tighten the pulley with some leads so that it does not turn, once you manage it, you begin to take out the screws and bolts from behind forward on the opposite side to the pulley, there are some where you must define the embopped, I do not remember if the Toyota will alternator
