Totoya Corolla 1999
14 ans 7 mois avant #19863 par manuelle mécanica
Totoya Corolla 1999 publié par Manual-mécanica
Hello, I have a mesh with my corolla, it results that 2 days ago I started to present problems what happens is that when the car is heard, I hear the revolutions go down and the revolutions suffer and I do not know what it will be because I thought that perhaps the injectors were dirty and I bought an additive but it turns out that it still does the same thing now does not know if the spark plugs will be It will be perhaps someone would help me with my problem
14 ans 7 mois avant #19865 par manuelle mécanica
Réponse manuelle-mécanica sur le re: Totoya Corolla 1999
Regardez si vous êtes intéressé, comment pouvez-vous affronter vous-même un scanner pour voir si c'est quelque chose d'électrique si vous voulez savoir à quoi cela ressemble, faites-le moi savoir soit
14 ans 7 mois avant #19868 par manuelle mécanica
Hello friend, the first thing would be to know if you have taken a good maintenance of your Toyota, that is, if you have changed spark plugs cleaning injectors and the main cleaning of the butterfly body and the IAC valve if you have not done any of that it starts there almost everything is relatively easy to do and if you want to clean the butterfly body in the network there are videos and pages that describe step to step by step how to do it. Preventive dans une voiture vous aidera à ne pas avoir ces échecs
