audi a3
14 años 8 meses antes #30699 por manual-mecanica
audi a3 Publicado por manual-mecanica
Buenos dias,
A ver si alguien me puede ecahr una mano, ayer le pase el vag a mi audi a3 y me salio todo esto:
0VCDS Version: Release 10.6.4
Data version: 20110418
Saturday,21,January,2012,13:28:02:10074
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8P34A142861 Mileage: 130090km/80834miles
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705
Revision: 12345678 Serial number: AUX7Z0D1FNO06P
Coding: 0000072
Shop #: WSC 06435 000 00000
VCID: 2759FFAFEF7D
1 Fault Found:
16785 - EGR System: Insufficient Flow
P0401 - 000 - -
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
VCID: 3A7F36DB0CCF
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
Component: KlimavollautomatH12 0150
Revision: 030364 Serial number: 8P0820043D
Shop #: WSC 00000 000 00000
VCID: 2D550D87CD81
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0010602
VCID: 43814B3F7B05
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000012
VCID: 306B14F3DAB3
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 F HW: 8P0 920 930 F
Component: KOMBIINSTR. VDO H25 0140
Revision: D09 Serial number: 2241DD09042460
Coding: 0004103
Shop #: WSC 03358 572 89296
VCID: 356525E725D1
1 Fault Found:
00003 - Control Module
014 - Defective
gracias
