ET Y Ruentas for Xsara
14 years 10 months before #18315 by manual-mecanica
ET Y Tires for Xsara published by Manual-Mecanica
I wanted to know if someone has an idea of ​​whether I can mount some +power leader 303 or some similar cn throat cn 205/40 r17 in an xsara 2 vtr? will pass the ITV or open problems cn measures and the ET?
thank you.;)
14 years 10 months before #18373 by manual-mecanica
Manual-Mecanica Response on the Re: ET and Tires for Xsara
Hello, if you can tell us what measure you have now could be advised what measure you can put without having problems when it will pass. : Dry:
14 years 10 months before #18381 by manual-mecanica
Hey as such! Well look at that one I have put you is an ekivalence that if you can mount the Q Yeo q is 195/55 r15.
And I wanted to know if the tire + power 17 "I would jale if I will touch me or had to put separators and others that that does not happen.
I like that style of the xo tire xo x example fuy to a feuvert and they tell me that that cannot be Mia
14 years 10 months before #18423 by manual-mecanica
Hello partner I feel the delay in answering you but I had to look for information about your tires. I comment, the tires +power 17 Leader303 You cannot put them in your car because: 1. Missed of tire 17x7 ET45 is a dezplagasimiento in within 45mm with respect to the center of the throat tire you would have about 42.5mm. anchor point. 2. In the front of the car if you can put them but you could not turn the steering wheel to the ancestor to the wheel point to the wheel pass your car has approximately 270mm.3.In the rear would enter only the tire without a pneumatic tire even very fair because from the anchor point to the rear bridge support you have about 135mm. The summary that you cannot put them in majority of tires that have the ET 35-40. And the separators can be put and homologated without any problem. :(
14 years 10 months before #18429 by manual-mecanica
Yee Q passes nene! Thanks for the information, even you have ended up disappointing a little hehey good sq in my coxe it seems that there are no models of the Qsten Wapos tire to put on it.
Anyway, I will check the measures and try to look at something similar in qme tires and the separators the truth SQ do not give me many to put them, xo weno see si cnsigo d Once to put tires since I proposed it for when I will change the tires.
Greetings, see you au.;)
