Electrical problem in an Opel Zafira
18 years 11 months before #956 by manual-mecanica
Electrical problem in an Opel Zafira published by Manual-Mecanica
: Cry:
Hello this is the first time I enter the forum and I hope it is not the last.
I have a problem, for my serious one, which is as follows:
my car is an Opel Zafira 2.o Dti Club and I am looking for the workshop manual of this car, since the backward lights do not show me, I have checked with a polyimetter if it arrives current to the caps but nothing arrives, so I think it is from the valve that it has, supposedly in the exchange box, which I do not see already I have already dismant And I don't see her, you can say please where he is to be able to change it and tell me where I can get off this manual.
Thank you so much.
18 years 11 months before #991 by manual-mecanica
Manual-Mecanica Answer on the Re: electrical problem in an Opel Zafira
For this you do not need the manual, right now I explain it to you:
the valve that is failing to you is located in the Zafira gearbox, not inside the cabin and you must look for it on the left part of the car, just in front of the pedals to put it in some way, at the top of the gearbox you will find a square box where the shilling of the lever enters its side is what you are looking for.
You will recognize it because two cables arrive with a connector and if you jointly with the contact you will see how the backward lights are lit.
PD not to confuse with a round round displacement with three cables (black, blue and black-red) because that is the gossip of the accounting and has nothing to do.
PD 2 I have been curing in Opel so I trust that what I have explained to you will help you ok ??
Receive a cordial greeting.
18 years 11 months before #992 by manual-mecanica
Another thing that I forgot:
this wonders in the "mechanical problems" section
since they are going to throw the peta x talk about this x here !! Ok.
Greetings and hopefully it is easy for you to find the problem.
