Peugeot 306 Release Problem
16 years 2 months before #9280 by manual-mecanica
Release problem Peugeot 306 posted by Manual-Mecanica
Hello everyone:
I have a Peugeot 306 of the year1999. It has problems with the relief when it stops works well and when I do not stop and it is blocked, I have taken it to the Peugeot and they have told me that everything is fine, but he remains the same, see if there is someone who can help me that it happened to him.
Greetings and thanks.
16 years 2 months before #9281 by manual-mecanica
Manual-Mecanica Response on the Re: Relay Problem Peugeot 306
Hello partner, check the temperature probe that is running well and the vehicle speed sensor, also check all emptiness hoses, luck and greetings.
16 years 2 months before #9290 by manual-mecanica
How do you stay blocked? The Relay is regulated by the IAC using signs of the revolution and temperature sensor, check this valve in general the scanner do not detect it because the IAC valve is an actuator and not a sensor.
16 years 2 months before #9295 by manual-mecanica
Do you want to break the release regulator? This rgulator works if I remove the connection begins to fail
the release, and the revolution sensor is the one that goes in the engine bollant?
I also carry a sensor I believe in the admission collector, I don't know if it works,
greeting and thanks for the information, what happens is that I have not been able to buy the book because they no longer do it.
16 years 2 months before #9298 by manual-mecanica
Halaurin Try on this bookcotalle.net there page I think you get it, you have to register but it's easy and free, greetings.
