Seat Cordoba Problem 98
18 years 9 months before #918 by manual-mecanica
Seat Cordoba problem published by Manual-Mecanica
Well I tell you my problem, I have VAT with the car and I warmed up a lot, I opened the expansion boat and it was dry and around the week I pushed water, fill it again to see if I threw it down somewhere, and nothing was thrown away when the car cooled again with luxury again, but a week or so it has happened to me again that it turned it off and when I cooled it, it did not have it again and when it turned it to me, when I swallow it, it had it again, when I got it back, when I got it, he had it again Looking a mechanical friend above says that it is the water pump that has gone and that I need to change the pump and because of the pump also the distribution strap because it has taken the clearance and the strap of the elements, (alternator and others) I pay attention to it because I will change it selflessly, but I wanted to know the opinion of you of the disbursement, greetings and thanks
P.D: He said that in a childhood about 150 euro imagines but already called me when I consult.
18 years 9 months before #970 by manual-mecanica
Manual-Mecanica Response on the Re: Seat Cordoba Problem of 98
Pay him attention, he is right, and I am also a mechanic and looks at the water pump.
Give thanks that you have not loaded the cylinder head for the warmth. The next time something like that happens to you, with which it warms the first time, because the water of the expansion vessel does not go anywhere unless you have a serious problem.
So if you see the empty glass from good to first = fat problem. stop and let cool and right to workshop than if not even the fattest.
Anyway, it has had to throw water little by little for some time. Because these things "warn" and I already tell you that the water does not disappear because yes, in addition, on the right side of the engine, below and near the transmission of the right wheel, you will see pink or green red traces of dry antifreeze because it has thrown it x there that is where the pump is.
Greetings and invites to dinner at your colleague ....XD
18 years 9 months before #985 by manual-mecanica
Thank you, I just changed the water pump and that the blades were broken they were plastic and broke has put me with the metal blades and 200 euro has come out all the two straps and the thermostat. Greetings and thanks.
