Ford Explorer Loming Failure
16 years 3 months before #8745 by manual-mecanica
Manual-Mecanica Response on the Re: Ford Explorer Failure
I will try to look for something and send it to you, but it may only be the cables not the compu or the coil I lean for there, since another problem would not send any
16 years 3 months before #8852 by manual-mecanica
: Dry: Look at that I am sure if the coil is not the fault, is that the cable that feeds that part of the coil is failing, that has 4 cables 3 of food and 1 of food
16 years 3 months before #8858 by manual-mecanica
First of all thanks, do you know how I can measure them? Do you have any circuit? Do you know the values ​​and what part do they come from? A hug Julio
16 years 3 months before #8861 by manual-mecanica
I Plublique a manual called Raster 1 Fig
16 years 3 months before #8863 by manual-mecanica
Thank you, but unfortunately it does not appear.
