I have problems with Peugeot 307 SW
16 years 4 months before #8359 by manual-mecanica
I have problems with Peugeot 307 SW published by Manual-Mecanica
1.6 HDI 16V engine. Start and stop fuel pressure rise.
16 years 4 months before #8360 by manual-mecanica
Manual-Mecanica Answer on the Re: I have problems with Peugeot 307 SW
Do you comment that it starts and stops, I don't think it is a high fuel pressure, how have you verified it?
Try another key in case it was a decoded key, if you do not pass me the motor code and if you have checked the low and high pressures and I tell you, it is not usually typical a high pressure, if not the setback I hope it helps you help you.
Greetings from Tenerife
16 years 4 months before - 16 years 4 months before #8362 by manual-mecanica
The code that accuses the SCAner is P1166- Pressure regulation function
when it starts in the scanner marks the fuel pressure 1800 bar La Low does not remember it, when it reaches that value it stops, when the pressure goes down after a while of being stopped starts back and again the pressure goes to 1600-1800 bar and turns to.
If you need more data, tell me ...
from thank you very much
greetings from San Pedro Bs. As. Argentina
Latest edition: 16 years 4 months before by .
16 years 4 months before #8412 by manual-mecanica
What happens to you is that the engine drowns through a fuel excess passes arto to the Peugeot, they do not cut the spark but it is dema fuel remembers the pressure and the flow is not the same, check the pump flow.
16 years 4 months before #8415 by manual-mecanica
Good, look at the crankshaft position collector. That goes on accessory pulley, many times gives problems. All the best.
