Fiat Palio Motor Fire Year 2005
16 years 7 months before #7400 by manual-mecanica
Fiat Palio Motor Fire Year 2005 published by Manual-Mecanica
Hello friends, I would like to know if there is any way to extract lkos fault codes from a Fiat Pale Pale Fire without using a scanner because mine I have in repair, thank you very much and a cordial greeting to all.
16 years 7 months before #7405 by manual-mecanica
Manual-Mecanica Answer on the Re: Fiat Palio Motor Fire Year 2005
It would be an importing that you told us that happens to your car and the other way by code of lights Nose recommends or used in your vehicle, apart from that if you are equibo you can damage the computer.
16 years 7 months before #7406 by manual-mecanica
I forgot, you would have to get the meaning or decoding of the codes and that is very difficult.
16 years 7 months before #7407 by manual-mecanica
Thanks Kikemec I will see how I fix the car, it accelerates alone and when I bass bass then repeats the cycle a hug.
16 years 7 months before #7410 by manual-mecanica
If it accelerates alone and this is in Relay Deves to check between unwanted air these are after the flow, it usually goes through a malfunction of the IAC valve, which in your case is a Magnetti Marelliprueva disconnect it with the engine walking, if it accelerates more it is fine if not, you can make a maintenance of it or change it.
