Peugeot 306 '99 heating does not work
16 years 8 months before #7050 by manual-mecanica
Peugeot 306 '99 heating does not work published by Manual-Mecanica
Hello, the first thing to give thanks for helping us solve this type of doubts.
My problem is that yesterday I left the hot air passage given and turned off the engine, the next day when it starts it did not come out of air, try to change the outer passage and then interior but the hot air does not work and in these cold days at dawn it shows. I have also proven that by pressing the AC button does not work either. The radio located above and the clock below the heating controls work. Could you please help me/guide me to solve this problem ???
Greetings and thank you very much in advance.
16 years 8 months before #7054 by manual-mecanica
Manual-Mecanica Answer on the Re: Peugeot 306 '99 heating does not work
Hello, if the heating does not work, it can be to melt the fuse.
16 years 8 months before #7064 by manual-mecanica
I think the fuses in the same way and after discarding them we talk about something else, for example, many kisses pass that the ruling potentiometer is cut and only works in an end diet at the fourth speed.
16 years 8 months before #7072 by manual-mecanica
Ok, thanks, I will check the fuses and I tell you.
16 years 8 months before #7120 by manual-mecanica
Ok do not hesitate to ask any questions
