Fiat Doblo Motor Failure
15 years 8 months before #13105 by manual-mecanica
Manual-mechanics' response on the topic Re: Fiat Doblo engine failure
It's definitely the injection pump. First, scan it and tell me what the scanner says. I've come across more than one of these, and the pump has to be replaced.
Cheers.
14 years 11 months before #18694 by manual-mecanica
Help! I need a good mechanic for my 2003 Renault Doblo, 1.9 diesel engine, which is leaking oil and has other problems.
I'm here in Santiago.
Thanks!
14 years 2 months before #26941 by manual-mecanica
Hi, I have the same problem too. The mechanic hooked it up to the diagnostic machine and it didn't show any faults. I'm going crazy trying to find the problem. What was wrong with yours in the end?
14 years 2 months before #27069 by manual-mecanica
I have had several similar problems in Renault and it is the rotation sensor of the injection pump that when starting does not detect whether or not and then it stays in the emergency phase and does not accelerate.
