Megane II noise
16 years 9 months before #6339 by manual-mecanica
Manual-Mecanica Response on the Re: Megane II noise
Happy 2009, Gracis for all the details, yesterday I did the test since 2nd, there was no noise, I did not test in setback but I remember that in some appropriate it did it in motion back, that you think it happens, the next week I go to the concessionaire where I bought the vehicle.
16 years 9 months before #6340 by manual-mecanica
Possibly, if when starting in 2nd it does not do it and in reverse sometimes (it depends on whether you accelerate or not when it comes out) it can be something as simple as the supports of the exhaust tube, some are broken, or loose or given of itself, or the same escape is lazy, and when the engine is challenged in its accommodation when the clutch is released (when the car throws), and pulls the tube.
Test with the engine stopped, cold tube (not going to be warm) you put behind the car and grab the exhaust nozzle, then shake it violently, with all the force you can, from top to bottom, from Izquise to the right and from the forest back, if it makes noise case resolved.
All the best.
15 years 11 months before #10552 by manual-mecanica
Do you regret buying the megane 2 ???? I want to buy 1 ... Model 2007 2.0 16 V Sedan ... in Colombia ... but I have seen several problems with this car ..... They told me that it disarmed ... but that the 2008 no longer had that problem ... it will be that I risk with a 2007 ... or the 2008 are still having these problems? .. Thank you.
15 years 11 months before #10574 by manual-mecanica
Hello, I am not really very happy with the vehicle, apart from the problem of the noise of which I made reference, which was solved was a motor soprte that was something spent. I change it and disappear noise. In 3 years with the car that changed as pieces are the pills (shoes) of the front brakes for normal wear, for the rest the car is excellent has a spectacular road performance, I have the Full 16V version, 2.0lts-Cot of retractile glass and leather upholstery. I recommend the car widely. By the way I make the recommendation of the Bosch fr7dc+ spark plugs
15 years 9 months before #11520 by manual-mecanica
Manual-Mecanica response on the topic not condemned
Hello good morning, someone knows "not condemned" in a megane II. Today after doing it stop and when trying to start that message appeared and the car did not turn on. Cerre the car with the control, I reopened it and esncendio later. The same thing is successful for a year and a half, Alguein knows what happened. I wanted to know who has a megane II and in what position is the recent temperature indicator I have noticed that it is almost hiding the line of the center, already check the refrigerant
