Passat TDI 110 CV Power Loss
16 years 11 months before #5869 by manual-mecanica
Passat TDI 110 hp power lost by Manual-Mecanica
Good morning and thanks in advance, I am a rookie and I need help for my car, you can see a lost power loss (such as when the air conditioning enters), you could guide me, it only happens in seconds of second
thank you.
16 years 11 months before #5880 by manual-mecanica
Manual-Mecanica Response on the Re: Passat Passat TDI 110 CV
This jump in the power occurs when the Acone air equipment is activated. These cars have a very good equipment and of course it is maintained with engine power, there is usually a sensor that accelerates the engine a bit when the air connects, if the engine is in idle, but, it is very normal for this to happen, it is nothing serious. In my Mondeo there are times that if it connects when you are leaving the engine stops, the blow of the pulley to \ "paste \" in the compressor is quite strong.
16 years 11 months before #5881 by manual-mecanica
You can also look at the electro -ventilator, when the electro starts it has an electric low and the engine falls, you can check if this is raising the cape and looking at the electro fan, if when it turns on it falls on power it is simple it is simple the electro, it is normal and it happens to us all, I also have a VW and the same thing happens to me.
LUCK
16 years 11 months before #5883 by manual-mecanica
Thank you very much, just tell you that I carry the air conditioner off and the same pulls are noticed, the speed peak takes it well but notice these little losses, flow?
16 years 11 months before #5889 by manual-mecanica
I do not think it is the cudalimetro, since for what you explain is a second and it is normalized, I repeat you look at the electrventilator ...
