please urgent distribution citroen saxo 1.5 d
16 years 10 months before - 16 years 10 months before #5781 by manual-mecanica
Please urgent Distribution Citroen Saxo 1.5 d Published by Manual-Mecanica
Hello friends, someone could tell me how to mount the distribution of a 1.5 d saxo I don't know if the cylinder No. 1 should be in pms or not ... I do not have the manual and I do a bit liado ,,,,, thanks colleagues
Last edition: 16 years 10 months before by .
16 years 10 months before #5791 by manual-mecanica
Manual-Mecanica Response on the Re: please Urgent Distribution Citroen Saxo 1.5 D
If the number 1 cylinder has to go in the PMS, but some belt manufacturers marked.
16 years 10 months before #5795 by manual-mecanica
If you have to be in PMS of cylinder 1, cylinder 1 is the one that is stuck to the gearbox, you first have to track the steering wheel to remove the pulley from the crankshaft, then take out all the plastic plastics. tension, then important the crankshaft rotates in a scoring direction and verifies marks again and is soon
16 years 10 months before - 16 years 10 months before #5811 by manual-mecanica
I put you for this post the scheme of how you go mounted the distribution of the saxo. If you see it too small, post your email address or complete your profile and send you expanded via mail ok?
16 years 10 months before #5834 by manual-mecanica
Thank you very much to everyone,
it is lucky to count on you
the car I already have it in progress, it costs to start but I suppose that it will be the heaters who fail
thanks for everything
