Toyota Corolla alert light 2006
17 years old, 10 hours earlier #5700 by manual-mecanica
Toyota Corolla 2006 alert published by Manual-Mecanica
I have a yellow light of main remain, which indicates and how we remove it_
17 years 8 hours before #5704 by manual-mecanica
Manual-Mecanica Response on the Re: Light alert Toyota Corolla 2006
How many km does the car have? Because most likely, I indicate \ "periodic review program \" that is, you take it to change the oil and filters.
All the best.
16 years 11 months before #5709 by manual-mecanica
The car has 32,000 km, all the filters were already replaced, in addition to the change of spark plugs and brake review, but the light is kept on, there is a better to reset it
16 years 11 months before #5718 by manual-mecanica
In the Autodata it says that the Corolla does not carry scheduled maintenance light, but a fault light.
The corolla verse however it has a light, but it is only for the change of oil, it puts oil change and is located to the right of the whole in the painting.
So I think something has happened then and the switchboard has detected a fault code. Try to mouth the battery for a whole night to see if it is reset and the fault code disappears. If it disappears and the light does not turn on again, there is no problem, if it turns on again, there is an engine failure and if so, the scanner will have to pass (and of course if the light does not turn off when you connect the battery again the battery will also have to pass the scanner).
All the best.
