Peugeot 306 hdi engine stops
15 years 6 months before #13260 by manual-mecanica
Manual-Mecanica Answer on the Re: Peugeot 306 hdi engine
Greetings to all, the fault has returned, the car has stopped again when I was in the idle, but this time I cannot start it, fuel pre -food does not occur and there is no way to start it, I have reviewed the inertial stop button and the fuses but without result, in the network I have seen that some have failed the double surround, the food pump and a connector that is under the left lighthouse Check these, but as soon as I do the results as I call for those who have happened something similar to tell me how I solve it, I think they are damages in this most frequent model than normal, greetings to all
15 years 6 months before #13290 by manual-mecanica
The 306 carry a multifunction relay behind the battery next to the brake fluid boat that when it is heated short injection and when it cools again again.
15 years 6 months before #13293 by manual-mecanica
Greetings to all, Ivacoma Thank you very much for your answer, I have to check that double reluct Lamina that makes contact) makes a good contact or if on the contrary it does not touch with enough strength and there is that stiments occur in contacts and sometimes a failure in the connection, I will review it and post the result.
15 years 5 months before #13774 by manual-mecanica
Greetings to all, after being for three or four days, turning the problem, check the fuses of the habitaculus, one by one I took them away, reviewing and putting again and at the end I put the contact, without much conviction the truth, and "voila" the fuel pump made the fuel load and start, I have been checking it during all these days and has not failed again, the possible fault would previously Agus0812. If he failed again or if on the contrary he does not fail again, a greeting.
15 years 5 months before #13801 by manual-mecanica
It has been faster than I would have wanted, today the car has stopped again when I was in the id operation, then it has been verified that the fuel came out by all the pipes of the low fuel pressure circuit, then we have started the car and it has worked without the smallest failure and has only stopped when I have removed the key, it seems that there can be an excessive pressure in the low circuit and makes the engine stop and until that pressure does not fall or disappear that press A call to everything that something similar happens to post it, greetings.
