Terrible problem with Ford Ka 1300
17 years 1 month before #4984 by manual-mecanica
Terrible problem with Ford Ka 1300 published by Manual-Mecanica
Hello guys, to see who can help me ... the Ford Ka, I stop and there is no way to start it. I have changed drums, starter engine, starter alternator cable, spark plugs and still stop ... It has been in a Racing workshop for a week and they have no lame ... S of what happens to it ... it can be the coil that gives current to the spark plugs ... please help. I am costing me a pastay they have no eggs to solve it ... Thank you ..
17 years 1 month before #5003 by manual-mecanica
Manual-Mecanica Response on the Re: Terrible problem with Ford Ka 1300
Let's see, more slowly, the first thing you tell me is that he stops, not that he stopped. With which it wants to say that it starts when it comes out of the fig is not?
Or what stopped you and did not start again? That is something that would be important for you to make clear.
Another thing, what do you change the starter engine to a car that does not start?, If the start turns at an adequate speed when you give the key because it is evident that the problem does not come from there. The same goes for the battery, you may have exhausted to turn and symplently would have been downloaded by consumption.
Taking it to a preparation workshop is neither good nor bad, but it would be better to take it to a Bosch Car Service or a workshop of the network ad o a site of which you can trust and also have a diagnostic machine to be able to discard things. (Taking it to Ford, I don't tell you because they see you a ball stick is already a breakdown chumina).
Let me know as soon as possible ok?
17 years 1 month before #5015 by manual-mecanica
Thank you, Megabeat_1, I shorten the explanations ... I changed the engine, those of the racing ... I put a new one, according to them .., and then stop and do not start again ... they put the same one that I carried, and even returned some pasta (€ 109). And that is when I changed 2 spark plugs, the spark plug wires and the cable of the starter alternator ... from Saturday is in the workshop, and today Monday at 18.00, they do not find the failure ... I will go to look for it and take it to another workshop, which they have told me that they are good ... I will tell you ... and thank you ...B)
17 years 1 month before #5016 by manual-mecanica
17 years 1 month before #5017 by manual-mecanica
Very good, I believe if your car arrives correctly working to the ´Racing workshop all motor components as their accessories are fine, and with the other engine I should start, I think it is a matter of the negligence of the mechanics that are chapusers, and I have made you spend a paste that you denounce them ,,, Greetings.
