Blazer ignition problem
17 years 2 months before #4793 by manual-mecanica
Blazer ignition problem published by Manual-Mecanica
Hello everyone I have a 1996 Blazer Automatica Vortec, it has been a while since I started I thought that it could be battery problems since the board indicator decreases to less than 14 (average) buy a new 75 battery but it does not turn out either and when I try to turn on, I boto all the water, I think that by the radiator ... I hope and help me
17 years 2 months before #4796 by manual-mecanica
Manual-Mecanica Answer on the Re: Blazer ignition problem
Hello partner, if the engine expelled the water through the radiator or the expansion boat, it is due to strong overheating.
The overheating can come for several causes:
1st Broken thermostat, so that the water of the cylinder head does not go to the radiator and begins to boil, take pressure and jump the radiator cap.
2nd fan drive and the warehouse pump, broken or out of place, if the pump does not rotate, the water does not move and the result is the same.
3rd in city driving, rupture of the \ "viscous link \" of the cooling fan (Fan Cluch). In this case, as soon as the vehicle could circulate faster, the temperature would drop immediately.
4th burned butt joint. If the engine has lost water due to some leak, or breakdown and has heated strongly, it is possible that the Culatt Board (Head Gasket) has burned, when this occurs, the compressed gases of the cylinders escape to the oil crankcase and also to the water cameras located in the butt, producing the same effect as if there were water vapor in the cooling circuit, the gases move the water and therefore the water Motor does not refrigerate, heated even more and the problem increases to the point of breaking the engine.
Another thing, do you mention that you have been with problems for the motor start time, one question: did you change the battery because the starter engine turned slowly? or on the contrary, it turned at a normal speed but the engine did not turn on?
If the start turned at a reasonable speed and the engine took to turn on, or turned on three cylinders or headed, it is a clear symptom that there is very little compression in the engine and that the butt joint is burned.
With whatever you let me know. All the best.
All the best.
17 years 2 months before #4797 by manual-mecanica
1.- The truth is that Boto Agua after a cold accelerated, that is, I manage to turn it on and accelerate it to full, planning to load the battery, had not thrown the water before.
2.- Light the \ "Check Gages \" indicators, battery and motor, the battery indicator was very low, it usually made a bridge to start at 3 or 5th attempt to start the engine, I bought an adequate battery in amperage (it had one of 55 now it has a 75), it no longer shows the battery so low, but it does not start.
17 years 2 months before #4798 by manual-mecanica
The witnesses Check Engine, and Check Gauges (or gages), should be extinguished as soon as the engine starts, if they were turned on during the march, the right thing is to stop
immediate The opposite first gave you the failure not to turn on the engine, without any witness being lit in the painting.
All the best.
17 years 2 months before #4799 by manual-mecanica
They only light at the beginning, it looks like a general check also passes through \ "abs \", and others then go out, but the battery is on.
