Rocy a few rpm
3 years 8 months before #54311 by manual-mecanica
Rocy a few RPM posted by Manual-Mecanica
Good, I inherited a Piaggio X7 Evo 300 IE of 2012.
The fact is that it was maintained and some arrangements, it has the new regulated valves, oil and filter, an electrical failure was fixed and the thermostat was changed.
I have been using a few months and has begun to make a noise in the clutch area, when the thermostat reaches the midpoint of the total temperature, at low revolutions it makes a very strong noise like friction, which stops sounding if I climb, in addition to the motorcycle progressing badly when it is touching.
The clutch is centrifugal, so they have told me that it can be wear of the shoes and that is why it stops sounding up, because it squeezes more against the bell, but it is surprised that it is just when the temperature rises, just like any cracked shoe that dilates for the heat? No idea.
The fact is that I do not have a euro for the mechanic, I know people who could help me disassemble and so on, but I don't want to play it to save for a clutch, rent a box, open and see that the problem did not come from there.
Has this happened to someone else or could you give me any information? Because I don't know what to do anymore, if I get some slaughter because I ask for money or whatever and arrange it, but for now I can only look for advice, thank you.
3 years 7 months before #54317 by manual-mecanica
Manual-Mecanica Response on the topic to a few RPM
Reading your situation I would take her with professional mechanic or at the same agency.
____________________________
electric scooter seller
