Citroen C5 2.0HDI Year 2012 Problem EGR
5 years 7 months before #54062 by manual-mecanica
Citroen C5 2.0HDI Year 2012 Problem EGR Published by Manual-Mecanica
Good to everyone,
I write this because my brother's car has problems due to the EGR, but it has changed it to a new and follows the problem even more than before. The problem is that it throws it when the car is cold, then it seems that it is removed. We have also realized that when disconnecting the EGR connector does not give pulls. Does anyone know what system can be associated with the EGR and give those failures when you connect it again?
PD: The fuel circuit is clean as the ultrasound injectors were cleaned and filters were changed. The EGR was also cleaned.
Greetings and thanks in advance.
