Citroen C3 Patina clutch, new oil stained disc
6 years 1 week before #53945 by manual-mecanica
Hello, about 3 months ago I put the clutch kit, the problem I gave me was that I skated, especially in the long climbing and velocideaes, it was revolutionized and not for strength, I changed a mechanical supposed, since I did not go to a workshop, when disassembling the disc was full of oil, so we changed the retain of the crankshaft, once mounted on a few days I noticed the same day. This time I noticed a weird smell when I kicked, according to Valvulina, I recent smell.
I think he's doing something wrong, some retain that does not change, I don't know.
Let's see if someone guides me
a greeting
6 years 1 week before #53946 by manual-mecanica
Manual-Mecanica Response on the Citroen C3 Patina clutch, new oil stained disc
Greetings, from what you describe, the fault is the Hydraulic seal of the Prinincipal Axis of the box. The strong smell you perceive is from the oil of the box that is similar to that of the valvulina. That supposed mechanic, unfortunately, did not have the necessary knowledge to solve your problem since the beginning of it.
5 years 11 months before - 5 years 11 months before #53964 by manual-mecanica
Thank you friend for your answer, a week ago I speak with which I change the clutch and also the gearbox, I told him that I kept smelling the same, he told me to continue trying it, from time to time I look under the car in case the gearbox dripped, this last time he dripped was the brake fluid of the clutch's bombim, that by the way I changed it and finally I think that the smell is now. clutch, I did the test with the hand brake and the second speed placed and the car was hard for him to penetrate.
I was watching clutch videos on YouTube from a mechanic (Daniel Paul) and explained all the problems that could be in the assembly of a clutch, one of the problems that I commented talked about the fork and a teton that changed, could go out there the shots, I did not problem.
All the best
