XR2 85 Missing D
17 years 2 months before #4584 by manual-mecanica
XR2 85 Missing D Published by Manual-Mecanica
I have an XR2 of 85 Q I want to get after 4 years I have changed Kit D dist. Water and gas pump Filters d spark plugs and spark plugs and then all this when it goes from 2750 laps more or less falling down. Do you think what can it be?
17 years 2 months before #4598 by manual-mecanica
Manual-Mecanica Response on the topic Re: XR2 85 Missing D
Hi Franin, as tried to disassemble the entrance of gasoline, carburetor, or intimacy and groove it, you would see the gas flow that releases, you can prompt to take with a bottle with a little gasoline, and place it directly to the carburetor, see that the deposit is not dirty, or the hose that carries the gasoline.
Luck. Already in front of that machine.B)
17 years 2 months before #4599 by manual-mecanica
gracias bielas le he quitado el carburata lo he llevado a un taller ¡¡¡q solo trabaja carburadores!!! Not even injection and the uncle had spare parts of all the membranes joints and has changed them and the entrance valve! Q was screwed: Woohoo:
17 years 2 months before #4606 by manual-mecanica
I am glad Franin, the truth is not sap if I wore carbureta or ingecation, but we are going with a difference I keep carburation. You are very careful to take care of it a lot, that and few cars like that are seen.
Luck.B)
