Ported door
17 years 2 months before #4503 by manual-mecanica
Ported door published by Manual-Mecanica
Hello good afternoon, I have a problem with the left back door of my Volkswagen Passat of the year 97.
It turns out that the windows of that door did not work very well and the centralized closure did not work either I had to lower the pestillo with the finger.
Well, I have fixed it with scrapping pieces but to change those pieces I have had to disassemble the lock, the window .. The issue is that I had to release a steel cable that goes to the outer handle.
After having everything montadito and operating the door from the outside 2 or 3 times until Sono clack hahaha the cable had released from the outer handle and I said so listillo I would open inside but inside but hahahaha is safe of the children was activated and can only be deactivated by opening the door hahahaha than whore more big Panel and there is no way to start it since it is caught with the door.
CONCLUSION:
After much fight and break the panel the door does not open on the outside or inside it no longer makes me laugh hehehe.
I have called a choricillo and says it is impossible to open it without breaking the sheet.
Someone can give me some solution for this problem.
In the official house they will charge me a safe paston, a neighbor of mine is a chapist and wants to burst my sheet something that gives me less laughter and ami I think of removing the cracking of the handle and drilling the piece that is removed to disassemble the lock and with some pillos pill the cable and pulling to open.
Any solution less than dressed than the previous ones ????
Thank you very much to all and a cordial greeting
17 years 2 months before #4671 by manual-mecanica
Manual-Mecanica Response on the Re: Ported Door
Ayyy mother !! What gardens have you signed up!
We are talking about the back door, and you say that the inner panel does not take off? Not even dismantling the rear seat?
Try to break everything you have to break inside, which after all is cheaper and easier inside than on the outside, it is not the same to put a scrapping door panel than an entire door of scrapping. (Apart from color, door state and blah blah blah and the price is not the same)
it breaks the inner panel if necessary, but what you have to do it from within, that once there is no panel, children's insurance and the mechanics of the handle are accessible from the inside.
Greetings and go putada !!
17 years 2 months before #4681 by manual-mecanica
The best way to open it is to break the inner handle, access the cable and pull it. When you spend the outer handle again, leave a little tolerance to the PQ cable but what happened to you. This is used for all vag models
17 years 2 months before #4698 by manual-mecanica
Remember that you have the children's insurance on the door, try the door to reach the lock so that you can overwhelm it or try to reach the lever that presses the handle to open the door, take out all the internal accessories handles and the rest and if I do not make the lid, the lid comes out tinge Havia above.-
17 years 2 months before #4705 by manual-mecanica
It occurs to me rather than damaging everything do cars thieves to open doors: remove the packaging from the window or moon or as the Lame Glass calls in some parts. This is very easy and the space that remains with a long screwdriver or a flat lever and a flashlight tries to manipulate the palanquita that operates the sheet. To give you an idea of ​​how mechanism works, disassemble the panel from the other door and thus define the best way to open it. But you also close the other, hehehehe.
