Toyota Tundra 2007 ABSC ABSC VSC
9 years 9 months before #50694 by manual-mecanica
Toyota Toyotra 2007 ABSC VSC Published by Manual-Mecanica
I wanted if they could help me to know the cause of why the spotlights of the ABS and VSC of a Toyota Tundra 2007 were lit
9 years 9 months before #50698 by manual-mecanica
Manual-Mecanica Response on the Toyota Tundra 2007 ABSC VSC
The causes for which the ABS anomality light comes on and the VSC could be several, the ideal will be to make a diagnosis, but if you want to try something that fails with some frequency in the aforementioned system, check the brake pedal switch, I put a photo in case you do not know it.
