Failure codes in a Hyundai Tucson 140 hp CRDI
9 years 9 months before #50688 by manual-mecanica
Failure codes in a Hyundai Tucson 140 hp CRDI published by Manual-Mecanica
I have an Hyundai Tucson D4EA Diesel Motor 140 hp after changing the turbo by breaking
9 years 9 months before #50689 by manual-mecanica
Manual-Mecanica Answer on the topic Failure codes in an Hyundai Tucson 140 hp CRDI
Because of the failures you mention, your engine is in a state of emergency by decision of the ECU that limits it by 3000 rpm as a prevention.
The code P 1405 refers to the temperature of the EGR out of rank.
Code P 2002 refers to the party filter, which you say to have changed, but it is possible that as in the majority of the vehicles that have this element, its function must be reprogrammed with scanner once replaced.
