CD4E Ford Escape Transmission Failure 2002
10 years 1 month before #50184 by manual-mecanica
CD4E Ford Escape 2002 Transmission Failure Published by Manual-Mecanica
Hello mechanical partners ....... I have a 2002 Ford Escape with 4 -speed automatic transmission is the CD4E but it turns out that the first and second one enters very well but does not change to third or fourth speed ... and after 3000 revolution A diagnosis and did not come out of a sensor or solenoid .... I only throw these two codes that leave me in the same P0733 and P0734, that the only thing that tells you is that it does not change to third and Metallic and pasta and drums and everything is fine, even change the valve box and check the solenoids and all are fine but the transmission nomas does not change ...... I hope and someone gives me some idea something that happened to me ...
10 years 1 month before #50185 by manual-mecanica
Manual-Mecanica Response on the topic in Transmission CD4E Ford Escape 2002
The gears checked them to see if it is not marked or insurance is moving
10 years 1 month before #50187 by manual-mecanica
Yes ..... but everything is fine, they don't have wear ..... Tomorrow I will take the computer to check if it does not disrupt ... and if it is fine, it will no longer be left to do ...... Thank you for taking the time to answer a companion.
10 years 1 month before #50188 by manual-mecanica
P0733 Generic Gear 3 Incorrect Ratio
P0734 Generic Gear 4 Incorrect ratio
When brand failure in gear relationship at a certain speed, it is usually mechanical failure. Did you check the double drum? In this drum applies forward /direct that the applications influences 3rd and 4th. Check this drum very in detail because they crack and it is very difficult to detect the fissure. Also inspect the status of the pistons working in this double drum.
Luck !!
The next user said thanks: Test1
10 years 1 month before #50189 by manual-mecanica
Also check Forward's sprag ...
