Clio 1.4 16v Power problems
17 years 3 months before #4343 by manual-mecanica
CLIO 1.4 16V Power problems published by manual-mecanica
The car with 14800 km and 2 years and 2 months one day I turned on the catalyst pilot and the car had a loss of power and pulls I took it to the official service
because I had the extended guarantee and in one hour two of the coils that go to the spark plugs that go after 8 months do the same thing. Electronics and that you can fail some of you can make some comments to me
17 years 3 months before #4348 by manual-mecanica
Manual-Mecanica Response on the Re: Clio 1.4 16v Power problems
Good morning.
The coil, or coils, of a vehicle is an electric piece that during its operation is subjected to high electricity discharges and very heat which facilitates its deterioration due to the effort to which it is subjected. In your case it is not a problem of deterioration of the piece itself, but a manufacturing defect of the K4M engines (14. 16V) engines. Renault has a technical workshop note regarding this breakdown, the solution is to replace the 4 coils with other modified.
You will wonder why the 4 coils did not change the first time. It can be for two reasons:
- The first and most important thing is that they changed them because you have an extended guarantee. The expanded guarantees do not depend on Renault, but on private insurance companies to which you have to request authorization to do the work on the car, if the insurer does not authorize it, it is not done. It is not done because but not charged.
- The second is that the mechanic who did the repair was a patán or someone in practice, something very common in official dealers. If ten people are template; Only one has adequate knowledge of mechanics and electronics, the rest are \ "Cambiaceites \" or kids in practices.ç
Greetings.
