SUPPLY SUSPENSION SUPPLY SUP. Ford Explorer
10 years 4 months before #49683 by manual-mecanica
SUPPLY SUSPENSION SUPPLY SUP. Ford Explorer published by Manual-Mecanica
Good morning everyone, I am new for the neighborhood.
I have a 4x4 Ford Explorer 96. It has the upper front suspension kneecars spoiled and I want to change them. Those of origin cannot be changed, everything must be changed, the arms included. I try to disassemble the driver's arm and I can't, the screws that hold it are long and run into the shock absorber support that is soldier to the chassis.
I thought about cutting them and then riding them in the reverse, that the screw head comes out on the other side, which there is space.
Do you know any other solution or trick?
10 years 4 months before #49686 by manual-mecanica
Manual-Mecanica response on the topic Front Suspension SUP. Ford Explorer
Attached photo of the blissful screw.
First topa with the fluid tubes, the raffle (with enough difficulty) but when they stop with the steel support it is already impossible. If the head were the other way around there would be no problem, it would come out perfectly.
