Fiat point 1.4 8 valves, does not start
10 years 6 months before #49286 by manual-mecanica
Fiat point 1.4 8 valves, does not start published by Manual-Mecanica
It does not come spark, the coil works, it does not turn on the gasoline pump either. I ask, does anyone know if any fuse or reread main can cut both at the same time ??? Please help ...
10 years 6 months before #49289 by manual-mecanica
Manual-Mecanica response on the Fiat point 1.4 8 valves, does not start
Look if your car is equipped with the Impact button, the Fiat is usually close to the tormes of the shock absorbers, under the capo. The other can be the anti -start or immobilizer if your key has transponder.
Now I send you an image where the relay 9 marks that it is of injection.
I hope it helps you.
Luck
10 years 6 months before #49290 by manual-mecanica
This is the image
10 years 6 months before #49296 by manual-mecanica
The possibilities that you mention are correct. Also on this site there are manuals that can help it. In case of the point of any vehicle Fiat 1.4 Fire could ervir. The strange thing is that you have no witness on the board. Therefore, the only one that cuts without indicating is inertial. Greetings and luck
10 years 6 months before #49298 by manual-mecanica
Dear, a common fault in these Fiat is the crankshaft position sensor located on the side of Dumper, checks its correct subjection of the same and its connector, this in its failure shorts the signal to the coil and the fuel pump. You tell us how it went. Luck.
