Palio Diesel went out and I don't start anymore
11 years 6 months before #46516 by manual-mecanica
Good evening fellow forum members, my name is Reni. I have a 1998 Fiat Palio 1.7 diesel. I loosened the timing belt because it was very stretched and I felt a clunk. When I put it back on, the sprocket connected to the injection pump slipped about 5 teeth. I started it without problems, the only issue was a knocking sound that stopped after 2 kilometers and it ran normally. I drove another 75 kilometers and it suddenly shut off without any noise or anything. I've noticed that the injection pump isn't sending diesel fuel, and I replaced the entire shut-off solenoid that goes to the pump just in case. It shut off without any hesitation or anything; it's as if it ran out of fuel or something like that. I hope you can help me. Thank you in advance.
11 years 6 months before #46517 by manual-mecanica
Manual-mechanics response on the topic: Palio diesel shut off and won't start again
Did you check the timing belt?
11 years 6 months before #46522 by manual-mecanica
Yes, I checked and everything is fine, nothing came loose or broke.
11 years 6 months before #46523 by manual-mecanica
As your colleague huipi mentioned, you should "check the timing belt" or its alignment, as it's not normal to start the engine and hear a knocking sound. You said it skipped about 5 teeth on the water pump, but you didn't say if it also skipped on the crankshaft sprocket or camshaft; valves could have been bent if this happened. I hope you have luck, and definitely check the timing and turn it by hand before starting the engine. Regards.
11 years 6 months before #46528 by manual-mecanica
Thanks for the advice. I wanted to let you know that only the sprocket connected to the pump turned; the rest didn't. Is it possible that I can drive 75 km without any problems and that the valves are bent? I'm asking because I'm completely inexperienced with this. Thanks.
