Lose oil from the cylinder
17 years 4 months before #4093 by manual-mecanica
Lose oil by the cylinder published by Manual-Mecanica
I have a BMW 1100 gs, since I change the engine oil, it is losing me a little oil that is the cylinder
17 years 4 months before #4109 by manual-mecanica
Manual-Mecanica response on the Re: loses oil through the cylinder
To determine if you lose by a cylinder you should inpece the spark plugs if they are with the symptoms of an oil loss by the cylinder. As a question, don't you have leaks outwards? I recommend that you make a gas exam. Report me to see how you are going.
17 years 4 months before #4113 by manual-mecanica
Hello the scheme is losing me for the base of the cylinder
17 years 4 months before #4114 by manual-mecanica
You already do not know any system so that the injector butterfly does not make me is annoying noise, apparently it has a little game due to the km that the motorcycle has ............ Thank you
