Help with fuel indicator problem
11 years 11 months before #44974 by manual-mecanica
Manual-Mecanica response on the subject Help with fuel indicator problem
If, at all times, either with the engine on or off, with the key or without it, with the switch open or closed, it does not make any movement, so I asked if there was any specific fuse to this indicator, and I do not know if this has something to do, but when starting the engine, or giving the key they light the lights and always remain like this, I have not found any switch to disconnect them to disconnect them
11 years 11 months before #44979 by manual-mecanica
Hello everyone, heretic, for what you say, my ipination never moves is that the problem is in the instrument panel. If the fault be in the fuel aphorador in the tank when removing contact, if the indicator in the table is ok, this should be in rest position. If the system fuse burns by a short, it would always be in rest position. On the lights depending on the market where the car was sold, they can be permanent or some person as you say they leave them directly with sheet on. greetings.
11 years 11 months before #45044 by manual-mecanica
Thanks for your help, having this reference I will review the operation of the indicator, thanks again
