Help with Contur 94 does not turn on
11 years 11 months before #44745 by manual-mecanica
Manual-Mecanica response on the subject Help with Contur 94 does not turn on
Hello everyone, Ishmael effectively, OBD1 (Diagnostic system on board first generation is analogous to the Opel Aldl (OBD1 GM). I agree to what Ishmael expresses (caudalimetro), but the oscillations caught my attention, ami opinion is that it can also be the TPS, or butterfly The system has 2 problems at the same time, temperature sensor more caudalimetro, it would be rare, but not impossible ... no to all.
11 years 11 months before - 11 years 11 months before #44746 by manual-mecanica
Hello everyone would be interesting to hear the opinion of this whole community greetings to all. :)
Last edition: 11 years 11 months before by .
11 years 11 months before #44747 by manual-mecanica
Hello, well, to determine if it is the flow, I advise to disconnect the tab and start; If you continue doing the same as if you were connected, you can say that the problem is already solved ... Greetings !!!
*Thanks for the doubt about OBD1 !!
11 years 11 months before #44773 by manual-mecanica
Hi Ismael 53 What happened is that the car was perfectly well but like this and without avizo I stopped working, I started cheating the why and I had how much I had not pulse in the injectors in any and for what I got a computer with the same series very characteristics and everything in short an equal changed it and ready problem solved the car the car began to work perfectly well but it is going to the engine. I was passing too much air through the managing, I check all the empty and then I realized that the harness of the maf of air mass was in poor condition because I already repaired it and I went out there that that could be the fault and then the tps Position of the pedal was loose I put it well and nota the problem is that I already provided the 2 sensors and the computer in the expense of a friend of a friend. Well and I have no idea that it can be tomorrow I upload a video of the fault that causes to have a better notion about the fault because today I spend all day checking again what I had already checked and nothing what Fiat147 says about how to scan it already found it on the web but I do not have the time to do it today I upload the video of
that
11 years 11 months before #44774 by manual-mecanica
Hello everyone, idle oscillations can be caused in that system by the oxygen sensor, test disconnecting it and observes if there are RPM Motor oscillations. Greetings.
