Help with Contur 94 does not turn on
11 years 11 months before - 11 years 10 months before #44891 by manual-mecanica
Manual-Mecanica response on the subject Help with Contur 94 does not turn on
Hello everyone, cook with you, nobody against anyone. I also respect your opinions very much, that's what it is about. Nor do I intend to compete with anyone, that stage has been spending a long time and I don't have to show anything to anyone, the only thing I wanted to do was help the Chabal and in my opinion you did not let the subject develop. When you give an opinion I personally try to learn from people with experience like you, always with respect. Co respect to EPROM, this system lacks this, has ROM and KAM memory, the introduction of EEPROM memories (Electically Electically Programmable Read-Only Memory) was later and if you do not think I find out, in fact the code indicated a lack of permanent feeding and with Cahpa on, if this is fine, it can be the ROM of the computer. I never said that the car's computer was bad, you had to read well to realize this. With respect to the distributor and ignition module, it is noted that he did not even bother to see the videos that the colleague went up, in which the DIS was clearly fantasized, with his opinion the only thing that achieved was to confuse and waste time to the colleague, which went to verify what you said, clearly without squeems to bother to see what the Chaqbal had posted. With respect to the diagnosis, for example, when a client reports a failure in the brake system of a car, you can change the complete $$ unit system, or perform the diagnosis to the brake system and then repair it? cordials !!!
Last edition: 11 years 10 months before by .
11 years 11 months before #44894 by manual-mecanica
Well, so that it has not misunderstood, on the page. 1 Say the opinion of caudalimetro or dis, then it has been told that it does not carry ... I cannot watch videos on my PC. The EEPROM or RAM or what it takes, I explain badly, what I mean in any case if it has a defect in any memory, you cannot be valid for self -escann, it is only opinion. I leave here the topic waiting for the result of the fault, thanks for your advice, without more, to follow the mechanical issue that is what interests everyone. Greetings!!
11 years 11 months before - 11 years 11 months before #44895 by manual-mecanica
Hello everyone, Mr. Ismael53, very serious about it, throwing the stone and hiding the hand ... Saco was harmed a propection colleague, who was asking for help in a complex problem. incist yourself recognizes not knowing the system, which you want me to think about it ...B) greetings. PS: People are not dumb ...
Last edition: 11 years 11 months before by .
11 years 11 months before #44896 by manual-mecanica
What I have seen are the photos, but if they tell me that it does not have Dis? Let's see, we understand each other: I said flow or dis, I don't care about MAF or MAP, Dis, I don't care about a coil on with a module, which has a distributor ... I refer to the ignition in general, this is in any gasoline engine. Opinion that it could be the failure of the flow, in view of what the partner said. Of wet spark plugs, I thought there was no spark Well, at no time have said that this evil, apologies. No one is dumb, of course, but it seems to be disturbed that I from some orientation, as if I say that it can be the temperature sensor failure, if it is not connected, or gives little resistance, etc., it will also bother you, respect you, respect the other opinions, let it be the one with the problem with the car, have other points of view, that it is the one who decides what is told. I don't know what you want by disqualifying anyone, it doesn't seem good to me, in short, I'm not here to discuss, I'm going to see the resolution of the fault, I suppose like everyone else, ok?
11 years 11 months before - 11 years 11 months before #44897 by manual-mecanica
Hello, the opinions are all valid with only one exception that of a person who appears, pulls pure ideas to the crazy, and then lies blatantly and then the victim is made, typical of a chanta. Incist did not realize that the only thing you dedicated to doing was, confuse the Chabal ... and I do not doubt your intelligence but of your intentions (you are an old fox) and way of referring to people when it expresses an opinion based on knowledge and/or experience you seem to exploit and come out a string of eggs of their mouth, without any support or source that supports what you say or be casts in the air ... You dedicate to ranting against modern technology "that Carburetors", "Machine" In this it is just bad intention and that bothers me. The other if you had only seen photos and not videos, because you told the Chabal that you did not know how to interpret those codes, and the left or right light? This shows that you lie blatantly and you had seen the videos and you played it crooked with the distributor knowing that I did not have ... Look could follow my intention is not to disturb anyone, but it gave me angry your attitude. In fact, if you had not dedicated yourself to confusing El Collega, we all know what the car had, incist I invite you to help the Chabal find if you give the failure. Always remember people are not silly. At least the people who followed this post learned to interpret codes for flashes in Ford Obd1, what was your contribution in this post? Finally if you want respect not disrespect to others ....B) greetings.
